Is it possible to get tags associate to a specific Asset ?
I mean using the REST API
Thanks
Fabio
Of course. The syntax is:
https://cloud.squidex.io/api/apps/squidex-website/assets?$filter=tags eq 'image' and tags eq 'image/large'&$top=30&$skip=0
It is a normal filter.
You can also check the docs for contents for more examples: https://docs.squidex.io/guides/02-api#usdfilter
Check the asset structure in the API docs for all fields: https://cloud.squidex.io/api/docs#operation/Assets_GetAssets
BTW: Everything you can do in the UI can also be done with the API. (Except creating apps)
Thanks for your answer, but probably I didn’t explain my request.
I have an asset (e.g. 6f0b0007-736a-4db5-beb9-34ea18416232) and I want to get its tags
Something like the following:
Request:
https://cloud.squidex.io/api/assets/6f0b0007-736a-4db5-beb9-34ea18416232?$filter=tags
Response:
“iv”: “6f0b0007-736a-4db5-beb9-34ea18416232”,
“tags”: [ “images”, “test”]
Fabio
Sorry. This API does not exist yet, it was just not needed. But you can use the assets endpoint with:
https://cloud.squidex.io/api/apps/MY_APP/assets?$filter=id eq 'MY_ID'
