Attempting to disallow or reject an update to an asset is not working so I can make changes my “Update” script shouldn’t allow.
When disallow() or reject("reason") are hit in an “Update” script it should not allow the update to go through and show error message to the user.
Add an “Update” script for assets containing:
disallow();
reject(“rejected”);
- Attempt to rename an asset (or perform any other update operation).
- The rename succeeds.
- [x] Self hosted with docker
- [x] Cloud version
Version: 7.2.0 - 7.5.0
- [x] Chrome (desktop)
I added same script content to the “Create” and “Move” events and it correctly stopped the operation from going through so I think this could just be to do with updating an asset.
Marked as regression as presumably this has worked in the past but this is the first time I have tried to use the update Asset script.
My app name with this script set up is called: slalfe-test
