Editing is disabled Assets scripts cannot be used with tooltips.
Is there a way to enable AssetS scripts to be used in the OnPremise environment?
Are you sure this is not a permission problem?
This account is Administrator and has * all privileges.
The same problem occurs when initially installing Squidex, creating an administrator, and creating a project.
I issued a token to that user and modified it through the API, and it works. This is an issue where only the UI is disabled.
I have a look later today or this week.
I have fixed it and pushed the commit to master.
The issue has been resolved based on the master version. Thank you.
