I’m trying to upload a JPG file that is < 2MB is size.
In my schema I’ve set the max size to 5242880 Bytes (5MB).
When I drag and drop the image to either a folder under the Assets tab or if I drag and drop a file directly into the Assets field in my content page I get a “Asset is too big”.
I’ve checked this thread. Not sure it’s related.
I first tried with version squidex/squidex:dev-3578 of Squidex.
Then I killed my pod and updated Squidex to version squidex/squidex:dev-4980 - same problem!
Any advice?
Thanks.
