Hello, I’ve read the documentation (and checked through a couple of support posts) but can’t seem to find a definitive answer - hopefully someone can help!
Is there a way to transform an asset id to a url when using a webhook? I understand there’s the “Resolve-Urls” header for the REST endpoint and wondered if there was anything similar?
I’ve already got the workaround of adding a hidden json field to convert it manually but wondering if there was a more “global” way (so I didn’t have to do this for each asset field for every schema)?
Thanks so much!
