API returns Header Overflow on get request
  • [ X] Bug report
API returns Header overflow error
Api should return the current data.
I am trying to send a get request for a table with ~200,000 records, I am retrieving a token from and sending it to the request, and the response I am getting is Header overflow.
I am sending a get request
https://cloud.squidex.io/api/content/my-server-name/tablename
the header is Authorization: Bearer token
and the request fails.
  • [ ] Self hosted with docker
  • [V ] Cloud version
  • [ ] Chrome (desktop)
    -[X] not applicable
Tried sending both via code, and as a postman request.
What query do you make? And who reports the Header overflow exception?
