404 Responses from Squidex
  • [x] Bug report
Since upgrading to the latest Squidex commit on master from 6.3.0 we are receiving a 404 response when accessing Squidex via the main base URL. Hosting locally via Docker I have the same problem too.
traceId: "00-e93184d2523abf5411d1448b20963c68-35fcefa4bbf1c23a-01",
type: "https://tools.ietf.org/html/rfc7231#section-6.5.4",
statusCode: 404
We can still access the login page via the known URL of
http://localhost:5002/identity-server/Account/Login
However all other requests appear to return a 404. The appsettings configuration for Urls I am using is shown below
	"urls": {
		"baseUrl": "http://localhost/",
		"basePath": "/",
		"enforceHttps": false,
		"enforceHost": false,
		"knownProxies": [],
		"enableForwardHeaders": true,
		"trustedHosted": []
Returns the default login screen or the apps screen when navigating to the base URL.
  • [x] Self hosted with docker
Version: 6.4.0(Latest master commit)
  • [x] Chrome (desktop)
I’ve tested this hosting via IIS and Kestrel and get the same result
Can you try to unset the basePath setting?
Hi Sebastian, I’ve unset the basePath setting and still receive a 404.
We have since moved to the tagged version 6.4.0 and can confirm it’s working.
I just tested it out and it works fine for me.
https://dev4.squidex.io/app,
Username: mail2stehle@gmail.com
Password: 1q2w3e$R
Hi Sebastian, we have been testing internally and believe we have identified the commit that is causing us issues.
Currently we generate multiple different appsettings.{environment}.json files for each environment that we deploy to for example
  • appsettings.environment1.json
  • appsettings.local_gb.json
  • appsettings.staging_gb.json
  • appsettings.live_gb.json
we then pass the ASPNETCORE_ENVIRONMENT={environment} into the container via environment variables.
From this commit onwards we have been been receiving a 404 when trying to use Squidex. There are some changes in the Frontend startup.cs that where the code doesn’t flow through the correct paths as our environment is not Development, Staging or Production.
Makes sense, because Squidex expects only Development and Production. It could be probably changed by changing every
if (IsProduction())
to
if (!IsDevelopment())
