Hi! Im playing around with thet CLI to figure out how to deal with schemas getting out of sync on our local environments…
In https://cloud.squidex.io/app I created two different apps and what i’m trying to do is to get a specific schema from app1 and then import (sync) it to app2…
Switching between the apps with config use <app> works just fine, so does schemas get schema1 > schema.json
But when i do  schemas sync schema.json after i switch between the apps i get this error message
"ERROR: The HTTP status code of the response was not expected (403).
Status: 403
Response:"
The error message is not really helpful…
