[INACTIVE] Squidex CLI: failed: Invalid command
  • [ ] Bug report
  • [x ] Documentation issue or request
We are trying to sync schemas and contents between two apps, but we are getting an error when trying to do so.
I’ve exported app-a with ./sq sync out ./test-a/ and trying to sync to app-b with ./sq sync in -t schemas -t contents ./test-a/. I’m just getting:
  • STEP 2 of 3: Importing contents started
Upserting #0… failed: Invalid command.
Upserting #1… failed: Invalid command.
Any idea of what this is?
I Expect that all the settings are synced to app-b without errors.
  • [ x] Self hosted with docker
Version: 5.7.1
CLI Version: 7.8
  • [ ] Chrome (desktop)
Sounds like a bug that is already fixed.
I’m on version 7.8 in the CLI?
No, it is API issue.
Oh. I will try that!
Hi Sebastian.
I’ve updated Squidex to 5.8.0 and tryed again - Same result.
Here I’m doing the sync out command: https://pastebin.com/fUJPFwbx
and the sync in command: https://pastebin.com/2TTcft2f
There is also some funky things going on in Squidex after this.
If I’m doing the same sync in command again, it gives me this output:
  • STEP 0 of 3: Importing Assets started
Uploading 962a258e-bea3-448b-9e1f-f78…succeeded.
Uploading 2ebe352a-6841-4e89-9a1c-969…succeeded.
Uploading 2ebe277c-f92e-459c-9771-0cb…succeeded.
Uploading 0dc1e061-87c2-4f43-a7cb-f11…succeeded.
Uploading 99fbe6e4-18c4-48de-8dfa-241…succeeded.
Uploading 48695994-e86b-4ac0-8373-14f…succeeded.
Uploading 508b4d3b-93e0-459e-abb4-470…succeeded.
Uploading f1598e9a-d889-4e97-8d2a-816…succeeded.
Uploading 45a1cee4-7aec-4e1f-bdf3-341…succeeded.
Uploading 27380185-510d-4879-a95e-efe…succeeded.
Uploading 35bbef13-fdb8-44a3-9189-157…succeeded.
Uploading 87ff4b1c-5f1f-4d9f-a53d-ba1…succeeded.
Uploading c9be3b59-7ec1-4b14-b837-f04…succeeded.
Uploading 22e0f414-5a9e-471e-8bbf-836…succeeded.
Uploading c687e8f2-f1a4-448e-a966-db6…succeeded.
Uploading 49335374-350e-4411-abbe-fbd…succeeded.
Uploading a675435d-0945-4cb3-ba2b-78b…succeeded.
Uploading ef559ccc-783f-40cf-a2a9-24f…succeeded.
Uploading 88a68c9a-5dfb-4219-b3d1-9fc…succeeded.
Uploading 0e754980-225a-4488-800c-d5c…succeeded.
Uploading fea617b6-20f4-4b4f-ae5a-7a3…succeeded.
Uploading ae38eccd-e8c0-471c-98d0-6b6…succeeded.
Uploading 2398a581-2838-4ea4-88b8-a7c…succeeded.
Uploading 2e5d4367-f5e1-4cc3-8a2b-3ba…succeeded.
Uploading 44f285aa-1341-4851-b1f8-4e0…succeeded.
Uploading 673759c4-a776-4893-97b0-287…succeeded.
Uploading 056be38d-faa0-449e-9a7f-bc9…succeeded.
Uploading 8df0e65f-4de1-4646-9ff6-6ba…succeeded.
Uploading aa264c03-a559-4e1a-be85-65d…succeeded.
Uploading e4f06090-59b9-4037-bec0-5d4…succeeded.
Uploading 94e4b627-f203-449f-930d-579…succeeded.
Uploading 425cfc35-5742-4d44-ab26-b22…succeeded.
Uploading 9677579f-288e-45e7-a883-57a…succeeded.
Uploading a7713f1d-9a4c-4605-9ba7-1a6…succeeded.
Uploading b6328eca-8e9d-44b6-bafe-a6f…succeeded.
Uploading d323d5db-c65b-45c4-bafd-6b5…succeeded.
Uploading 8000b6d1-2648-490b-9fb6-032…succeeded.
Uploading 9511cc9c-a63e-4579-8479-5cb…succeeded.
Uploading f8100b55-16ec-487b-988c-dd9…succeeded.
Uploading 8ff6238c-0a08-4d6c-95e8-b70…succeeded.
Upserting #0… succeeded.
Upserting #1… succeeded.
Upserting #2… succeeded.
Upserting #3… succeeded.
Upserting #4… succeeded.
Upserting #5… succeeded.
Upserting #6… succeeded.
Upserting #7… succeeded.
Upserting #8… succeeded.
Upserting #9… succeeded.
Upserting #10… succeeded.
Upserting #11… succeeded.
Upserting #12… succeeded.
Upserting #13… succeeded.
Upserting #14… succeeded.
Upserting #15… succeeded.
Upserting #16… succeeded.
Upserting #17… succeeded.
Upserting #18… succeeded.
Upserting #19… succeeded.
Upserting #20… succeeded.
Upserting #21… succeeded.
Upserting #22… succeeded.
Upserting #23… succeeded.
Upserting #24… succeeded.
Upserting #25… succeeded.
Upserting #26… succeeded.
Upserting #27… succeeded.
Upserting #28… succeeded.
Upserting #29… succeeded.
Upserting #30… succeeded.
Upserting #31… succeeded.
Upserting #32… succeeded.
Upserting #33… succeeded.
Upserting #34… succeeded.
Upserting #35… succeeded.
Upserting #36… succeeded.
Upserting #37… succeeded.
Upserting #38… succeeded.
Upserting #39… succeeded.
  • STEP 0 of 3: Importing Assets completed
  • STEP 1 of 3: Importing Schemas started
Schema app-configs updating… skipped: Nothing changed.
Schema sites updating… skipped: Nothing changed.
  • STEP 1 of 3: Importing Schemas completed
  • STEP 2 of 3: Importing contents completed
Synchronization completed.
So I thought huh, maybe there is some assets now. But when I browse assets, there is none shown with the filter All tags - If i change the filter to image I can see the desired images.
Other folders I get some exceptions in the squidex backend. See logs here: https://pastebin.com/dHrVWcKa
I will have a look, thanks … can you send me your export or database?
Btw: Are you using custom IDs? The invalid command error could be because of that.
We are not using custom IDs. I’ve sent you a backup of the app.
Thanks for your support, much appreciated!
Can you also send me the folder that is created by the “sync out” command?
I cannot reproduce it. I need the database update with mongorestore (https://docs.squidex.io/01-getting-started/installation/troubleshooting-and-support#prepare-a-backup-of-your-mongo-database) and detailed instructions how to reproduce it.
Sent you a dump of the squidex db and steps to reproduce.
Hi @Sebastian
I am facing the same issue while sync in only content of a specific schema is giving me this failed:Invalid command.
Is it a singleton schema?
I looked into this and observed those content which have localizable those content are giving me error. Other language is Chinese(Zh)
I think the only options to figure out what is going wrong are:
  1. You provide me a way to workaround this.
  2. You give me an export of your database and the source folder.
