I’m on Squidex Cloud, paid plan.
If you want me to try something just give me the steps and I will try it out for you.
Sorry, I have not deployed it yet. Will be done end of next week. I thought you are using self hosting
Okay, no problem. Just ping me when it’s deployed and I will test as soon as I can.
Hi Sebastian, I was just wondering if the fix has been deployed to Squidex Cloud so that I can test it?
It is planned for Monday.
Perfect, I’ve just completed the DELETE operation implementation for my Reviews feature in my app so it’s perfect timing. I will do some tests and get back to you.
I noticed the Algolia deletion fix has been deployed.
I delete an item from Squidex and it indeed deletes it from Algolia as well ![]()
What I’m wondering now is; I have not specified anything in the Deletion field in my rule.
Shouldn’t I need to put for example event.type == 'Deleted' || event.type == 'Unpublished' || event.type == 'Archived?
Hi, I have to roll back the version. Mongo CPU usage goes up like crazy. I am investigating the problem and will provide a fix asap.
Okay, np.
I noticed just now that Rules are not being triggered also.
I think the problem is solved.
Okay. I will test things out during the coming hours. Will report back.
Hi Sebastian, something is wrong. When I create a content item for my review schema the fields’ values are not being persisted. The content item is created however. Can you please have a look?
Please do not reuse the topic here.
They’re somewhat related but sure, I created a new thread ![]()
