[IMPLEMENTED] Schema content part / mix-ins / inheritance / snippets
I’d be great if there was a possibility to mix-in schema’s to other schema’s.
This means that if we add schema’s that have common fields, we only have to define the fields just once.
For example, we first define a schema named SEO with the following fields:
  • Title
  • Description
  • Keywords
Then when we define a different schema (Page or Blog for example), we can choose to mixin / inherit this schema so we automatically get these fields when we edit the content of these schema’s.
Good point.
As a developer you could use the sync feature and write a CLI for that.
Read more: [IMPLEMENTED PARTLY] Migrate schemas and rules between apps
Thanks, that’s pretty useful and we can sure use the CLI for our use-case. But it would still be a nice feature to have be able to include schema’s in other schema’s.
Sure, therefore I kept the feature request open.
I am closing this now. There is a new JSON editor, which can be used as a developer to copy and paste fields from one schema to another.
