If I delete the new app, I can back to the dashboard.
Should I pull down the latest?
You can try that, but you have to build it yourself if you use IIS.
The question is: Why do you get the 403?
No idea
I wish I knew! I’ll pull down the latest and see what I can get.
Very strange. I haven’t changed anything and it’s working this morning!
out of curiosity…does that news api route try to access “https://cloud.squidex.io”? It appears so from the initial review of the code. Yesterday, it was returning a forbidden/not found error message.
Today, it stalls in “pending” state for over a minute. It finally responses with a 500 internal server error. The FeaturesServices has these settings. Should URL be populated from options?
var squidexOptions = new SquidexOptions
AppName = options.Value.AppName,
ClientId = options.Value.ClientId,
ClientSecret = options.Value.ClientSecret,
Url = "https://cloud.squidex.io"
Yes, I have pointed you to the options. But as I said: In the latest version I just ignore errors and then it does not matter. It is not an important feature after all.
Gotcha! I must have misunderstood earlier. Shouldn’t the hideNews stop it from accessing it? Or that for something else?
Yes, I think so. I have done it for a client, but I do not remember the details
