Permanently delete schemas
An API leg where schema and event data can be permanently deleted. When a schema is deleted optionally, the data belonging to that schema can be permanently deleted. This may be specific to the dedicated hosting option. When a schema is requested to be deleted, a popup appears and all data and events (EventStore) belonging to that schema are cleared. In this way, garbage data is prevented from remaining in the database.
Makes sense, nothing to add here. We already have that for schemas, could be unified.
@Sebastian Hi, just a question because I’m curious - if enabling this flag now and if I understood you correctly it runs as background tasks, would this do a “cleanup” for already deleted schemas, i.e. cleanup lingering contents, relationships etc.? Thanks!
Yes, exactly. It should pickup everything.
