[NOT_REPRODUCIBLE] OrderBy doesn't work property with Id filtering
  • [X] Bug report
I have
  • An app that has users schema.
  • Users schema has username property.
I query users content with
  • a filter $filter that excludes predefined user ids.
  • sorted by username
  • (it may have $skip option).
In the end, the query looks like
$filter=id ne '<guid>'&$orderby=data/username/iv&$skip=10
The content is returned in a random order (not by username).
The content is returned in the correct order by username.
Note, the $orderby is working correctly if the $filter doesn’t have id filtering.
E.g, this query will work perfectly
$filter=data/uid/iv ne '<uid>'&$orderby=data/username/iv&$skip=10
  • [ ] Self hosted with docker
Version: [4.4.0.0]
  • [X ] Chrome (desktop)
  • [X ] Safari (desktop)
.Net Client Library 4.2.0
Have you tried adding ascendingt explicitely? Perhaps there is the bug, e.g.
$filter=data/uid/iv ne '<uid>'&$orderby=data/username/iv asc&$skip=10
I don see why it should be related to the filter.
asc or desc doesn’t help.
Request
{{squidex_url}}/users?$filter=(id ne '123' and data/fullName/iv ne null)&$orderby=data/fullName/iv asc&$skip=1
Response
    "total": 16,
    "items": [
            "data": {
                "fullName": "Khoa",
            "data": {
                "fullName": "Cy New",
            "data": {
                "fullName": "Khoa Dang",
There are 2 more notices:
  1. Even I repeat the same query URL twice, the response I got is different.
  2. I tried with a pretty old instance of Squidex (1.0.0), it’s working fine ;).
    Then, it seems some updates cause the issue.
fyi @Sebastian.
I tried it locally and cannot reproduce it. I also have some integration tests running for each build.
Strange! I tried to do the test on different projects in the same Squidex instance, the result is the same.
Anyway, I will check the version of Squidex again as well as looking into the integration test cases.
