[SOLVED] MongoDB error for graphql query
  • [x ] Checked the logs and have uploaded a log file and provided a link because I found something suspicious there.
  • [x] Bug report
Hello. I have the next failed graphql query:
Full error trace:
“logLevel”: “Warning”,
“action”: “reolveField”,
“status”: “failed”,
“field”: “queryEstatesContents”,
“exception”: {
“type”: “MongoDB.Driver.MongoCommandException”,
“message”: “Command find failed: Executor error during find command: OperationFailed: Sort operation used more than the maximum 33554432 bytes of RAM. Add an index, or specify a smaller limit…”,
“stackTrace”: " at MongoDB.Driver.Core.WireProtocol.CommandUsingCommandMessageWireProtocol1.ProcessResponse(ConnectionId connectionId, CommandMessage responseMessage)\n at MongoDB.Driver.Core.WireProtocol.CommandUsingCommandMessageWireProtocol1.ExecuteAsync(IConnection connection, CancellationToken cancellationToken)\n at MongoDB.Driver.Core.Servers.Server.ServerChannel.ExecuteProtocolAsync[TResult](IWireProtocol1 protocol, CancellationToken cancellationToken)\n at MongoDB.Driver.Core.Operations.RetryableReadOperationExecutor.ExecuteAsync[TResult](IRetryableReadOperation1 operation, RetryableReadContext context, CancellationToken cancellationToken)\n at MongoDB.Driver.Core.Operations.ReadCommandOperation1.ExecuteAsync(RetryableReadContext context, CancellationToken cancellationToken)\n at MongoDB.Driver.Core.Operations.FindCommandOperation1.ExecuteAsync(RetryableReadContext context, CancellationToken cancellationToken)\n at MongoDB.Driver.Core.Operations.FindOperation1.ExecuteAsync(RetryableReadContext context, CancellationToken cancellationToken)\n at MongoDB.Driver.Core.Operations.FindOperation1.ExecuteAsync(IReadBinding binding, CancellationToken cancellationToken)\n at MongoDB.Driver.OperationExecutor.ExecuteReadOperationAsync[TResult](IReadBinding binding, IReadOperation1 operation, CancellationToken cancellationToken)\n at MongoDB.Driver.MongoCollectionImpl1.ExecuteReadOperationAsync[TResult](IClientSessionHandle session, IReadOperation1 operation, ReadPreference readPreference, CancellationToken cancellationToken)\n at MongoDB.Driver.MongoCollectionImpl1.UsingImplicitSessionAsync[TResult](Func2 funcAsync, CancellationToken cancellationToken)\n at MongoDB.Driver.IAsyncCursorSourceExtensions.ToListAsync[TDocument](IAsyncCursorSource1 source, CancellationToken cancellationToken)\n at Squidex.Domain.Apps.Entities.MongoDb.Contents.MongoContentCollection.QueryAsync(ISchemaEntity schema, ClrQuery query, List`1 ids, Status[] status, Boolean inDraft, Boolean includeDraft) in /src/src/Squidex.Domain.Apps.Entities.MongoDb/Contents/MongoContentCollection.cs:line 88\n at Squidex.Domain.Apps.Entities.MongoDb.Contents.MongoContentRepository.QueryAsync(IAppEntity app, ISchemaEntity schema, Status[] status, Boolean inDraft, ClrQuery query, Boolean includeDraft) in /src/src/Squidex.Domain.Apps.Entities.MongoDb/Contents/MongoContentRepository.cs:line 81\n at Squidex.Domain.Apps.Entities.Contents.Queries.ContentQueryService.QueryByQueryAsync(Context context, ISchemaEntity schema, Q query) in /src/src/Squidex.Domain.Apps.Entities/Contents/Queries/ContentQueryService.cs:line 301\n at Squidex.Domain.Apps.Entities.Contents.Queries.ContentQueryService.QueryAsync(Context context, String schemaIdOrName, Q query) in /src/src/Squidex.Domain.Apps.Entities/Contents/Queries/ContentQueryService.cs:line 114\n at Squidex.Domain.Apps.Entities.Contents.Queries.QueryExecutionContext.QueryContentsAsync(String schemaIdOrName, String query) in /src/src/Squidex.Domain.Apps.Entities/Contents/Queries/QueryExecutionContext.cs:line 85\n at GraphQL.Instrumentation.MiddlewareResolver.Resolve(ResolveFieldContext context)\n at Squidex.Domain.Apps.Entities.Contents.GraphQL.Middlewares.<>c__DisplayClass1_0.<b__1>d.MoveNext() in /src/src/Squidex.Domain.Apps.Entities/Contents/GraphQL/Middlewares.cs:line 51\n— End of stack trace from previous location where exception was thrown —\n at Squidex.Domain.Apps.Entities.Contents.GraphQL.Middlewares.<>c__DisplayClass0_1.<b__1>d.MoveNext() in /src/src/Squidex.Domain.Apps.Entities/Contents/GraphQL/Middlewares.cs:line 28"
“app”: {
“name”: “Squidex”,
“version”: “3.4.0.0”,
“sessionId”: “5b24e8a9-afe1-493a-8529-57acc3f7f866”
The issue appears after some number of successful attempts.
Should return one document from the given collection.
Tested a few times with different combinations of top/skip parameters and it stopped working after some number of successful queries:
:heavy_check_mark: working fine:
  queryEstatesContents(
    top: 1,
    skip: 205
    id
  "data": {
    "queryEstatesContents": [
        "id": "c9c81a82-695a-4f8d-8e71-9e01b7d9805c"
:x: error:
    top: 1,
    skip: 206
    id
  "data": {
    "queryEstatesContents": null
  "errors": [
      "message": "Error trying to resolve queryEstatesContents.",
      "locations": [
          "line": 2,
          "column": 3
  • [x] Self hosted with docker
Version: [3.4.0.0]
  • [x] Chrome (desktop)
I am not sure yet, if this is really a bug: https://docs.mongodb.com/manual/reference/limits/#Sort-Operations
It should work for the default order. You can try to turn on profiling and then have a log which queries are used without an index.
For your mongodb instance
db.setProfilingLevel(2)
Thanks for your advice!
Yes, it was a Mongo error, there was no index for mt(lastModified) field. But I’m wondering, shouldn’t this index be created automatically? Does squidex have any interface for index creation?
Yes, this is strange, the indexes should be created automatically.’
Perhaps there is a bug that causes the method not be called or so…
I think I can also bypass this issue for other sort directions where an index does not exist.
The idea is to use the aggregation framework and to make 2 queries:
I have made an improvement to fix that or at least make it less likely to happen.
