Issues with our Import / Export Routine
#1
Hi there,
Was there any deployments Friday/Over the weekend at all. The export routine seems to have stopped working (as it was on Thursday).
Error with import/export functionality
  • export from cloud instance and import into hosted instance now fails if default app exists
2018-11-12T09:05:00Z: Started. The restore process has the following steps:
2018-11-12T09:05:00Z: * Download backup
2018-11-12T09:05:00Z: * Restore events and attachments.
2018-11-12T09:05:00Z: * Restore all objects like app, schemas and contents
2018-11-12T09:05:00Z: * Complete the restore operation for all objects
2018-11-12T09:05:00Z: Downloading Backup
2018-11-12T09:05:04Z: Downloaded Backup
2018-11-12T09:05:04Z: The app id or name is not available.
[x ] Regression (a behavior that stopped working in a new release)
[x ] Bug report
[ ] Performance issue
  • [ ] Self hosted with docker
  • [x ] Self hosted with IIS
  • [x ] Cloud version
  • [ ] Chrome (desktop)
I have deployed the new permission system this weekend and a few minor bugfixes. I will have a look to it this afternoon. It would be helpful if you can provide me a link to your backup.
What I do not understand is the following sentence: "if default app exists” … what do you mean with “default app”? A name with the same name or a different name?
Where do you export and where do you import?
#3
I have backuped my squidex-website app and restored it locally and it worked for me…
#4
We are still having issues and so I am going to have our Lead Dev, provide you with the details of what exactly isn’t working.
Thanks Sebastian,
Jason
#5
I’m following from where @Jace_Smiffy left off:
We have a hosted environment of Squidex. When restoring an export from the cloud-hosted version of Squidex and imported into this hosted environment we experience an error if no app name is provided.
  • If we provide a name for the application and it does not already exist then the restore works fine.
  • If the app exists and we try to restore over it the restore fails.
#6
That is not a bug. Squidex never deletes data. You have to delete your previous app if you want to create a new app.
But I solved a small issue when with the app name input.
#7
Thank you for the rapid response @Sebastian. So I guess we need to upgrade to the latest release?
However, I personally thought I was able to over-write the app on a restore. I may have been mistaken.
#8
Then the bug is that this is possible :wink:
#9
lol - let us assume it is. Would you be able to verify & if confirmed is it something on your roadmap to fix?
We are likely to upgrade our hosted version at some point in the coming week or so.
#10
So far there is no known bug for the backup and restore process. Usually I fix bugs as soon as possible. So if you can reproduce the bug today it is very likely that it is fixed until tomorrow
