[IN_PROGRESS] Schema Assets Folder Selector
It would be great if there was a feature when entity fields were created on the schema side and we could choose which folder to save the added content in. Currently, since the assets uploaded on the content side are added directly to the main folder directory, after a while there is a lot of accumulation and it is difficult to find them. It would be great if you can choose which folder to save in the asset field on the schema side.
it could be like this for example.
Thank you.
Thank you. I could also support a path, then the folder will be created automatically.
I already have the API for that. The advantage is that I don’t need a folder selector in the UI
ohhh google translate :frowning: I made a wrong sentence.
You can consider my first explanations. :crazy_face:
I reviewed the improvements in my local. Health to your hands.
it only shows the first folders in the root directory. does not show subfolders.
Can we expand the development here to include subfolders?
sample:
test
test > subfolder
test > subfolder > subfolder2
demo
demo > demofolder1
Thank you.
Yes, I know. I wanted to have something working first and then improve it over time.
