[DECLINED] Improvements Contributors: Confirm Dialog & Display Email
3 Simple UI features Requested
  1. Currently can’t see the email that was invited. The same system can have two people with similar names and hence it is difficult to delete a user
  1. Archive a User/Instead of deleting a user i.e disable a user before deleting a user
  2. Need Author Role by default who has just publishing rights (like a freelancer) who can be added into the system with an external login
  1. The email has been removed because other users had privacy concerns.
  2. You do not delete the user. He is just removed as a contributor.
  3. This is what custom roles are for. Not sure if it makes sense to add another default role, it is very special to your use case.
