I published a new version of the CLI that does exactly that.
When you retrieve a schema you can save it with the names of the referenced schemas
When you sync a schema this information is used to reassign the referenced schema ids.
Superb. I’ll give it a try over the weekend. Is see the new release on https://github.com/Squidex/squidex-samples/releases. I’m building the cli from the source which has not been updated yet (not pushed yet?)
Sorry, will do it tomorrow morning.
It is pushed. Btw: If you would implement a full sync over all schemas and rules it would be great
PRs are welcome
Hello,
I am getting an error when using the CLI.
I successfully add and then select the app I am trying to use. When I try any other commands with schemas I get
“ERROR: Unexpected exception occurred.”
Are there any logs I can look at for the issue? This error doesn’t tell me much
No, the error is stupid, you are right. Are you using the latest version? Can you send me the commands you entered? As PM if it contains private information.
I will add some logging by tomorrow.
