We can make a skype session to get it working if you want.
Thanks, yes I think I might need that! I’m working on something else at the moment, let me know when is best for you. It’s not critical for me so I can wait until next week.
Actually, ignore that.
I have absolutely no idea what I’ve done differently but it’s working this morning. I just copied and pasted the token info from Squidex as I normally do but the site is launching properly.
I assume I did something stupid before.
Thanks anyway
Hi @Sebastian
Do you have any Curl or Postman examples that you have used when testing authentication with Squidex.Identity?
Hi, I have used these examples: https://github.com/IdentityServer/IdentityServer4.Samples/tree/release/Clients/src
