How to add Azure B2c to Squidex
I cannot access the URL. When I open it, it does not give me any results.
@Sebastian
Can you point me to the correct configuration based on https://dynatexdigital.b2clogin.com/dynatexdigital.onmicrosoft.com/v2.0/.well-known/openid-configuration?p=B2C_1A_SIGNUP_SIGNIN
As you can see above I have not configured it. Usually it is just AUTHORITY_URL/.well-known/openid-configuration
@Sebastian
you mean: ```
"name": "IDENTITY__OIDCAUTHORITY",
"value": "https://dynatexdigital.b2clogin.com/dynatexdigital.onmicrosoft.com/v2.0",
"slotSetting": false
https://login.microsoftonline.com/{tenantId}/v2.0
@Sebastian Im using custom policy in azure ad b2c. It is not my login page
Then you have to check the azure docs how to configure the authority URL, I have no idea about the details.
@Sebastian I think authority is right, but I dont know Squidex get 500 error when finish login. The docker on my local is same error
