[SOLVED] Frontend Bugs (Datepicker Dropdown etc.)
Hi @Sebastian
I downloaded the master repository on github. Publish backend & frontend codes. Run solutions.
Datepicker days are mixed. dropdowns are disrupting in reference selections. there are many errors.
Can you make a new version by checking?
  • [X] Bug report
  • [ ] Self hosted with docker
  • [X] Self hosted with IIS
  • [X] Self hosted with other version
  • [X] Chrome (desktop)
Thank you, but I need concrete, reproducible bug reports, otherwise they have very little value for me.
@Sebastian
for example 24.12.2020 not saturday…
Thanks. Looks like a localization issue and easy to fix
Previous versions did not have such a problem.
Can you run a generic test for the master repository? There were also problems in relational areas here. Although the selected areas go well in the backend, there are problems in the frontend. I will be adding them as a screenshot. Do you plan to release a new version like 5.3 version after doing the general tests?
I think it happened when I introduced localization for the datetime picker. I am using this function. I guessing you are the US or so and because of your timezone a local offset is applied before formatting my dates and therefore your week days are wrong and they look okay on my machine:
EDIT: Just realized that it is monthIndex and not month. I hate javascript (sometimes).
