[IMPLEMENTED] Filter array fields
Hi Squidex Support,
I have a schema with a field of type array. It should be possible to filter this array type.
Best regards,
Jens Lehmann
Simple answer: No. But you are welcome to convert the question to a feature request :slight_smile:
It has been implemented:
The syntax is $filter=data/hobbies/iv/name='Programming'
Has also been deployed now.
