Hello @Sebastian and @ClaytonMoore
I’ve carefully reviewed this thread, and I don’t understand what I’m doing wrong. None of the things mentioned above are working for me.
An example of my test schema, which has just one string field, “stringField”:
"previewUrls": {},
"properties": {
"validateOnPublish": false
"scripts": {},
"isPublished": true,
"fieldRules": [],
"fieldsInLists": [],
"fieldsInReferences": [],
"fields": [
"name": "stringField",
"properties": {
"isRequired": false,
"isRequiredOnPublish": false,
"isHalfWidth": false,
"fieldType": "String",
"createEnum": false,
"editor": "Input",
"inlineEditable": false,
"isEmbeddable": false,
"isUnique": false,
"contentType": "Unspecified"
"isLocked": false,
"isHidden": false,
"isDisabled": false,
"partitioning": "invariant"
"type": "Default"
Example test content:
"data": {
"queryTestContents": [
"id": "4459f5c3-92c9-4555-a4fb-56d20cca6633",
"flatData": {
"stringField": "Test"
"id": "e703eecb-deab-43bc-bc5e-bbe4028cdff4",
"flatData": {
"stringField": "test"
"id": "85a2be10-d39a-4ac5-aefb-5585d2b4fe39",
"flatData": {
"stringField": "TEST"
"id": "41464cd7-0d95-487c-a581-d25daaa42307",
"flatData": {
"stringField": "tEST"
You claim that the eq operator should be case-insensitive, but that’s not the case:
Query:
queryTestContents (filter: "data/stringField/iv eq 'test'") {
id
flatData {
stringField
Response:
"data": {
"flatData": {
Query:
queryTestContents (filter: "data/stringField/iv eq 'Test'") {
id
flatData {
stringField
Response:
"data": {
"flatData": {
And so on.
You also mention that the tolower function can be used, but that doesn’t work either:
Query:
queryTestContents (filter: "tolower(data/stringField/iv) eq 'Test'") {
id
flatData {
stringField
Response:
"errors": [
"message": "OData operation is not supported for query: ?$skip=0&$filter=tolower(data/stringField/iv) eq 'Test'.",
"locations": [
"line": 2,
"column": 3
"path": [
"queryTestContents"
"extensions": {
"code": "VALIDATION",
"codes": [
"VALIDATION"
"data": {
"queryTestContents": null
Please help me understand what I’m doing wrong. How can I achieve case-insensitive queries with the eq operator in our Squidex instance? Our build version is: squidex:dev-8285.
