- Bug report
- Performance issue
- I created a schema, added a few records to the content, then updated the schema with a new field with default data. When I called
./sq contents enrich-defaults schema_a -u, the data was not updated in the Squidex.
- Data should be updated on the UI after calling the enrich-defaults command via CLI.
- Create schema
Item. - Add content to the
Itemschema. - Update the schema with a new field with a default value.
- Call
enrich-defaultscommand via CLI.
- Self hosted with docker
- Self hosted with IIS
- Cloud version
Version: 7.13
- Chrome (desktop)
- Chrome (Android)
- Chrome (iOS)
- Firefox
- Safari (desktop)
- Safari (iOS)
- IE
- Edge
Nothing
