Empty columns in listview when fieldname has subpart of another field
  • [X Bug report
In the listview when columns contain a subpart of another field the field is empty
field content should be output
I created a smal app with one schema to reproduce the bug
the schema “demo” contains two entries
in the listview “locationname” is empty, but if you click on the entry you see there is content. this only happens when the fieldname contains a subpart of another field “location”
https://cloud.squidex.io/api/apps/jobs/28c5fe58-29b8-4fde-8dcc-7120937f61d2?appId=fd33c318-5a2e-4d61-a0ed-d2ac1f95e08d
I have pushed a fix and will deploy it today.
