[SOLVED] Assets are gone after upgrade from 5.3.0 to 5.4.0
  • [x ] Regression (a behavior that stopped working in a new release)
  • [ ] Bug report
All my folders and assets are not listed in squidex anymore, after we updated the container image from 5.3.0 to 5.4.0 - All the assets are still in the blob container on Azure.
The strange thing is the filter bar is showing there is some assets:
But the api request does not return anything:
The container logs does not show any errors.
All the assets that I reference from a content item is also gone.
I expect all my folders and assets to be there
Upload assets when on version 5.3.0
Upgrade to 5.4.0
  • [ x] Self hosted with docker
  • [ x] Chrome (desktop)
  • [ x] Firefox
Do you have a 5.3 backup of your database that you send me?
Unfortunately I don’t. I only have a app-backup which I used to restore the app, so everythings fine again.
There is also something funky going on with folders now, or at least a different behavior. When I create a folder, it does not appear right away. Nor does the folders list in the Assets page.
The only way I can get in the folder is to click this little icon:
Then I’m here:
If I press the Parent folder, then the view changes to what we are used to
Is there anything else I can provide to help you solve this?
Can you send me your current backup of your database? (with mongodump)
Do you have all your assets in folders?
I will create a backup of my current database for you.
No, not all assets. But currently we’re using it as a whitelabel solution to store customer-specific assets in folders. But we also have some generelt assets for all customers. These assets are not in any folder.
I have found the issue. This version runs a migration that does not make sense if you have started with 5.3.
But you can set this flag to true and then restart your instance to repair your DB: https://github.com/Squidex/squidex/blob/master/backend/src/Squidex/appsettings.json#L704
Yup! That was it! Thanks a lot :slight_smile:
Any idea why the behavior with the folders that i mentioned?
The other problem is a UI bug.
Can you try dev-5312 tag?
Yup, that fixes the folder bug for me
