[SOLVED] 4.2.0-beta1 ValidationException
  • [X] Regression (a behavior that stopped working in a new release)
  • [X] Bug report
After (accidentaly) upgrading from 4.1.0-beta1 to 4.2.0-beta1 we are seeing a ton of ValidationExceptions (Cannot change status: Cannot change status from Published to Published.)
Full Log: https://www.dropbox.com/s/un4ndnffhnaqb23/squidex-validationexception-censored.log?dl=0
  • [X] Self hosted with docker
Version: [4.2.0-beta1]
This should come from the rebuilder, will be fixed soon.
wow, that was fast, thanks :+1:
You can just rollback. The rebuilder creates new collections and keeps the old collections in place.
